Hi, I am working on P1021 Reference Board. I have my kernel image present inside my sdcard. I want to flash it to my nand and nor from my u-boot. Please suggest any document that contain the information related to image flashing from u-boot prompt.
Hello Sourabh Das,
Please try to use the following method.
=>mmc read 1000000 0 10
( 0 is the device number, 10 is block number)
Flash uImage to NOR Flash
=>protect off <kernel_start_addr> +$filesize
=>erase <kernel_start_addr> +$filesize
=>cp.b 1000000 <kernel_start_addr> $filesize
=>protect on <kernel_start_addr> +$filesize
=>qix altbank
Write to NAND Flash
=> nand erase <kernel_start_addr> +$filesize
=> nand write 1000000 <kernel_start_addr> $filesize
You could refer to SDK 1.7 document from Freescale Technical Information Center .
Yiping
Hi everyone,
I'm a little bit confuse. If the <kernel_start_addr> is equal to Linux.uImage from NOR Flash Memory Map Table ?
Val
Yes, the <kernel_start_addr> is equal to Linux.uImage from NOR Flash Memory Map Table
Pavel Chubakov
