hi all
I saw a pcie msi issue on mpc8548e chip in MPC8548ECE document, i want to know whether p1010 have the same issue?
If p1010 don't have the pcie msi issue, can you explain how p1010 fix it?
thanks!
According to the P1010 errata the P1010 PIC does not have the same MSI issue. I guess they modify the PIC logic to fix the pcie msi issue. The P1010 PIC has IP version 3.1 while the MPC8548 PIC has IP version 2.0
hi Serguei
Thanks you quick replay, we met the same issue on p1010 platform described as MPC8548ECE, so I think maybe here have some problem.
Can you make sure this issue be fixed on p1010 platform? Or how to debug this issue on p1010 platform to verify ?
Dear Qingshan Li,
please create technical case (see See How I could create a Service Request? ) and describe your observation which make you conclude that there is MSI issue.
