Where is the hv.dts file in Freescale SDK 1.6 for P4080DS
ソリューションへジャンプ
1,933件の閲覧回数
peterzheng
I was trying to create 8 partitions on P4080DS using hypervisor.  I was following the documentation provided by Yiping.
https://community.freescale.com/docs/DOC-102249
However, I have trouble locate the hv.dts file. Could you help me with this issue? where is this file in the SDK after uncompress the ISO?
Peter Zheng
タグ(3)
1,564件の閲覧回数
lunminliang
Please check in attached hv-cfg-fsl-sdk-v1.6.tar.gz for SDK, under the path /p4080ds/R_PPSXX_0xe/hv-2p-Lnx-Lnx/hv.dts.
Also you can download from below for SDK1.6:
sdk/hv-cfg.git - Freescale PowerPC Hypervisor Config Tree
root/p4080ds/R_PPSXX_0xe/hv-2p-lnx-lnx/hv.dts
Is this what you want?
Lunmin
4 返答(返信)
1,565件の閲覧回数
lunminliang
Lunmin
1,564件の閲覧回数
peterzheng
Hi Lunmin,
Thank you for your help. Could you help me take a look at another problem?
how to create 8 partitions using hypervisor in P4080DS
Thanks & Regards,
Peter Zheng
1,564件の閲覧回数
lunminliang
Sure, I'll have a look soon later.
Lunmin
1,564件の閲覧回数
peterzheng
Hi Lunmin,
I was pointing you to the wrong question. Sorry about that. Can you take a look at this particular question?
How to partition the L3 Cacahe of P4080 using CodeWarrior?
Thank you very much for your time and help!
Peter
