Dear all,
In my design based on P2041RDB board, Altera FPGA is connected on SPI bus. I want to perform read/write operation on FPGA. Pls let me know what all drivers need to be insert to make it work.
My linux version is: Linux-3.8.13-rt9-QorIQ-SDK-V1.4
regards,
Gourav
Look at the Chapter 8.6 of SDK 1.4 documentation about eSPI using.
See also the Chapter 7.15 of SDK 2.0-1703 documentation:
https://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Pavel Chubakov
hi,
can you pls let me know about the spi-altera.c ? What is does and do i need to use it for my requirement ?
Can you pls comment on my above query??
Basically i need to transfer data from user space, to Altera FPGA which is connected on SPI bus. Not getting hint how to start..
regards,
Gourav
