Using MPIC when CPC is set as SRAM P4080
1,238 次查看
hymalaibello
I am using the CPC as SRAM, and I would like to know whether I can  use the MPIC (Multicore Programmable Interrupt Controller) while the SRAM configuration is enabled?
Thanks!!
Hymalai Bello
1,076 次查看
LPP
MPIC can be used without any relation to CPC mode.
Pavel
1,077 次查看
LPP
Pavel
