Below is P1020-WLAN Schematic. It says refer to P2020 datasheet, but P2020 RM has no information.
What is SENSE pins? Give me another reference please.
Best regards.
Solved! Go to Solution.
SENSEVDD and SENSEGND pins are connected to the VDD/GND planes internally and they were intended to be used by the core power supply to improve tracking and regulation. Then these pins were defeatured on the P1020 and P2020 because of an issue seen.
According to the latest P1020 Datasheet, Table 1. P1020 Pinout Listing, these pins are NC (No Connect) and it requires these pins to not be connected on the customer PCB
Andrei
Andrei
