Please refer to the following Patch of P1010RDB-PB with MT29F16G08ABABAWP NAND.
/* old board P1010RDB uses 512M NAND */
/* new board P1010RDB-PB uses 4k-pagesize NAND 2GByte MT29F16G08ABABAWP NAND */
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h
index ba3f7c2..f2493c5 100644
--- a/include/configs/P1010RDB.h
+++ b/include/configs/P1010RDB.h
* IFC Definitions
@@ -322,6 +321,8 @@ extern unsigned long get_sdram_size(void);
| CSPR_MSEL_NAND \
| CSPR_V)
#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024)
+#if defined(CONFIG_P1010RDB)
#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \
| CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \
| CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \
@@ -329,13 +330,25 @@ extern unsigned long get_sdram_size(void);
| CSOR_NAND_PGS_512 /* Page Size = 512b */ \
| CSOR_NAND_SPRZ_16 /* Spare size = 16 */ \
| CSOR_NAND_PB(32)) /* 32 Pages Per Block */
+#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024)
+#elif defined(CONFIG_P1010RDB_PB)
+#define CONFIG_SYS_NAND_ONFI_DETECTION
+#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \
+ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \
+ | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \
+ | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \
+ | CSOR_NAND_PGS_4K /* Page Size = 4K */ \
+ | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \
+ | CSOR_NAND_PB(128)) /*Pages Per Block = 128 */
+#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024)
+#endif
#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE }
#define CONFIG_SYS_MAX_NAND_DEVICE 1
#define CONFIG_MTD_NAND_VERIFY_WRITE
#define CONFIG_CMD_NAND
-#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024)
/* NAND Flash Timing Params */
#define CONFIG_SYS_NAND_FTIM0 FTIM0_NAND_TCCST(0x01) | \
FTIM0_NAND_TWP(0x0C) | \
@@ -349,6 +362,22 @@ extern unsigned long get_sdram_size(void);
FTIM2_NAND_TREH(0x05) | \
FTIM2_NAND_TWHRE(0x0f)
#define CONFIG_SYS_NAND_FTIM3 FTIM3_NAND_TWW(0x04)
+/* support MT29F16G08ABABAWP 4k-pagesize 2G-bytes NAND */
+/* ONFI NAND Flash mode0 Timing Params */
+#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07)| \
+ FTIM0_NAND_TWP(0x18) | \
+ FTIM0_NAND_TWCHT(0x07) | \
+ FTIM0_NAND_TWH(0x0a))
+#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32)| \
+ FTIM1_NAND_TWBE(0x39) | \
+ FTIM1_NAND_TRR(0x0e) | \
+ FTIM1_NAND_TRP(0x18))
+#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \
+ FTIM2_NAND_TREH(0x0a) | \
+ FTIM2_NAND_TWHRE(0x1e))
+#define CONFIG_SYS_NAND_FTIM3 0x0
+#endif
#define CONFIG_SYS_NAND_DDR_LAW 11
#ifdef CONFIG_MMC
#define CONFIG_CMD_MMC
#define CONFIG_DOS_PARTITION
@@ -613,9 +647,14 @@ extern unsigned long get_sdram_size(void);
#define CONFIG_ENV_SIZE 0x2000
#elif defined(CONFIG_NAND)
#define CONFIG_ENV_IS_IN_NAND
#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE
+#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) /* 3*16=48K for env */
+#define CONFIG_ENV_SIZE (16 * 1024)
+#define CONFIG_ENV_RANGE (32 * CONFIG_ENV_SIZE) /* new block size 512K */
+#endif
#define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE)
-#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE)
#elif defined(CONFIG_SYS_RAMBOOT)
#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000)
