SDK for P1022DS fsl-image-full misses some important linux folders
franciscojavie9
I have purchased QorIQ P1022ds. I have installed SDK and when I compile with bitbake the fsl-image-full, I got a basic Kernel. I wanted a kernel with at least a /usr/src/kernel folder to add a driver and compile it on my board. I have found other kernels for this board with this folder (usr/src/kernel)
Is there anything I can do to get a more complete kernel?
Thanks in advance.
franciscojavie9
Hello Yiping Wang,
Thanks again for your help.
When I generate rootfs by doing: bitbake fsl-image-full I got the following(*See below).
Once I have generated the following image: fsl-image-full-p1022ds-20170508082815.rootfs.tar.gz, I decompress it on /target/nfs doing this:
         sudo tar xzvf fsl-image-full-p1022ds-20170508082815.rootfs.tar.gz -C /target/nfs
When I get inside this folder, I still miss these folders.
Is there anything I am not doing correctly?
Thanks in advance.
FJM.
*BITBAKE Verbose:
WARNING: Duplicate inclusion for /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale-internal/conf/distro/imagedepends.conf in /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale-internal/conf/layer.conf
WARNING: Duplicate inclusion for /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale-internal/conf/distro/url-sha-references.conf in /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale-internal/conf/layer.conf
WARNING: Duplicate inclusion for /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-virtualization/conf/distro/include/virt_security_flags.inc in /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-virtualization/conf/layer.conf
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Parsing recipes: 100% |#########################################| Time: 00:02:18
Parsing of 2618 .bb files complete (0 cached, 2618 parsed). 3252 targets, 216 skipped, 0 masked, 0 errors.
WARNING: No bb files matched BBFILE_PATTERN_openembedded-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-oe/'
WARNING: No bb files matched BBFILE_PATTERN_multimedia-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-multimedia/'
WARNING: No bb files matched BBFILE_PATTERN_networking-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-networking/'
WARNING: No bb files matched BBFILE_PATTERN_perl-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-perl/'
WARNING: No bb files matched BBFILE_PATTERN_meta-python '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-python/'
WARNING: No bb files matched BBFILE_PATTERN_ruby-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-ruby/'
WARNING: No bb files matched BBFILE_PATTERN_filesystems-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-filesystems/'
WARNING: No bb files matched BBFILE_PATTERN_webserver '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/meta-webserver/'
WARNING: No bb files matched BBFILE_PATTERN_toolchain-layer '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-openembedded/toolchain-layer/'
WARNING: No bb files matched BBFILE_PATTERN_fsl-demos '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-fsl-demos/'
WARNING: No bb files matched BBFILE_PATTERN_meta-java '^/home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-java/'
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.26.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "powerpc-fsl-linux-gnuspe"
MACHINE = "p1022ds"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "1.9"
TUNE_FEATURES = "m32 spe ppce500v2"
TARGET_FPU = "ppc-efd"
meta
meta-yocto
meta-yocto-bsp = "(HEADdetachedfromb74ea96):ddf114933ccfc6e3ce51a10e8e8f95e514b73578"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
toolchain-layer = "(nobranch):214e1801d0efc38d3b6142bdc0d8e58ca593e34c"
meta-freescale = "(HEADdetachedat7fb32a2):7fb32a20983a0ebd5503eb42e851550b0deb8679"
meta-freescale-internal = "(HEADdetachedat220bff8):220bff8b2030e5af7393b5870d74c6f0af0d76d1"
meta-freescale-extra = "(nobranch):ced26c806cb566b1400a2f4f26a94d8d44d13233"
meta-qt5 = "(nobranch):90919b9d86988e7da01fa2c0a07246b5b5600a5d"
meta-fsl-demos = "(nobranch):17f9da65efb5c65c1d44b5cc18584034b29a742b"
meta-browser = "(nobranch):6ae140b29f0201fe3bb470da8c96c9e142294ebf"
meta-virtualization = "(nobranch):0277cbcb47db4239d0a4aa3b37c5c6a705070951"
meta-java = "(nobranch):d5a2a31aaad8f6bdf19860f7a858b10d7dba08b6"
meta-linaro-toolchain = "(nobranch):3f1933242062d1cf473d20b86fa4582963ff9441"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "(nobranch):0842ae59ce7f752aabb2459510739ec4fff8b33d"
meta-security = "(nobranch):aac972c0b88ce67a7bc9fcd83ee8793b61d4fff7"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-indra
meta-micapa = "<unknown>:<unknown>"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Preparing RunQueue
WARNING: /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_3.12.bb.do_compile is tainted from a forced run
WARNING: /home/edt/YOCTO/QorIQ-SDK-V1.9-20151210-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2015.01.bb.do_compile is tainted from a forced run
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 6033 tasks of which 6014 didn't need to be rerun and all succeeded.
Summary: There were 363 WARNING messages shown.
yipingwang
Hello Francisco Javier Munoz ,
The fsl-image-full has already included package  "kernel-devsrc", which is used to package Kernel source code in the folder /usr/src/kernel/ in rootfs filesystem.
Would you please let me know which folders you need but missing in the rootfs?
TIC
franciscojavie9
Hello Yiping Wang,
First of al thanks for replying.
The problem I got is that I miss these folders:
   /usr/src/kernel
   /usr/src/linux
   /lib/modules/3.12.37-rt51/build
The problem is that I want to install a driver after the kernel has run and the folders to install it must be inside those folders. I have tried on Ubuntu and it works, but in PPC P1022DS it misses sources to build the driver.
Is there anything I must add to generate those folders with the fsl-image-full?
Thanks for your help.
Have a nice day.
FJM
yipingwang
Hello FJM,
Just now I extracted a full rootfs filesystem QorIQ_SDK_V1.9_E500V2_20151210_ROOTFS_Image.tar.gz provided in SDK 1.9 pre_built image ISO.
Folders "/usr/src/linux/" and "/lib/modules/3.12.37-rt51+g43cecda/kernel/drivers/" do exist, these should meet your requirement.
How did you boot full rootfs filesystem?
Because the full rootfs image is too large, you cannot use ramdisk to boot it, it's better to boot it from SD/SATA/USB.
TIC
franciscojavie9
Hello again,
I installed the following:
QorIQ SDK V1.9 PPCE500V2 IMAGE
QorIQ SDK V1.9 SOURCE
I thought that rootfs was also included into these .iso files. They are aroung 4,5 GB.
The point is, how can I rebuild the rootfs to get all these folders? How can I check that I do not miss anything when I built the image?
Best regards.
FJM
franciscojavie9
I forgot to tell you that I am using nfs_boot to run it.
Best regards.
FJM
yipingwang
Hello FJM,
Please use the full rootfs image full-rootfs/QorIQ_SDK_V1.9_E500V2_20151210_ROOTFS_Image.tar.gz in the ISO QorIQ-SDK-V1.9-PPCE500V2-IMAGE-20151210-yocto.iso directly, it is also generated with the command "bitbake fsl-image-full".
$ sudo mount -o loop QorIQ-SDK-V1.9-PPCE500V2-IMAGE-20151210-yocto.iso ~/mnt
$ ls -lh ~/mnt/full-rootfs/QorIQ_SDK_V1.9_E500V2_20151210_ROOTFS_Image.tar.gz
-r--r--r-- 1 root root 318M Dec  7  2015 /home/b25805/mnt/full-rootfs/QorIQ_SDK_V1.9_E500V2_20151210_ROOTFS_Image.tar.gz
You could extracted your built full rootfs in a folder and check whether these folders "/usr/src/linux/" and "/lib/modules/3.12.37-rt51+g43cecda/kernel/drivers/" exist.
TIC
