Protect JTAG debugging of P1010 with challenge/response value
1,593 次查看
thomas_graziade
I am trying to secure the P1010 JTAG interface with a challenge/response value (SFP_DCVRn, SFP_DRVRn). Is there any working setup out there?
I found the following question here in this forum, but that doesn't seem to be answered
Can't get past SDC challenge/response using Codewarrior?
In the BDI3000 manual of the P1010 I cannot find a way to configure the response value. (Opposed to the BDI3000 manual for the P3/P4... series I can and it is called SDCRESP)
The Lauterbach manual also does not mention anything about configuring a debug response value. (https://www2.lauterbach.com/pdf/debugger_ppcpq3.pdf )
What do I need to make this work (JTAG HW, SW)?
Thomas
标签 (2)
1,472 次查看
ufedor
Please consider that NXP support is provided for the CodeWarrior only.
To obtain support for third-party tools please apply to their technical support services directly.
CodeWarrior Development Studio for Power Architecture Processors Targeting Manual contains description of the secure debug operation:
https://www.nxp.com/docs/en/user-guide/CWPADBGUG.pdf
1,473 次查看
ufedor
