Does P1020RDB-PD support loading bootloader(uboot) from SD card?
If so, what are the switch settings to load uboot from SD card?
I am using FSL SDK 1.8. The documentation lists the procedure to burn UBoot in SD card but does not say what switch settings to use.
Abdur Rehman
Solved! Go to Solution.
