P1010 booting from SPI
tsybezoff
Hi to all!
Please, help me)
I can't understand how to boot my project code into SPI Flash.
As I know, I need to create a configuration file and my user code image. How can I do this using Code Warrior IDE?)
Tags (3)
roybieda
Have you had a chance to look at this Application Note?: http://www.freescale.com/files/32bit/doc/app_note/AN3659.pdf
lunminliang
Some related information can be found in Targeting_PA_Processors.pdf, section 6.1 Working With Flash Programmer and appendix C Memory Configuration Files. The document is in the CodeWarrior installation directory, C:\Program Files\Freescale\CW PA v10.x\PA\Help\PDF.
