I am using P4080DS board, I tried to run Packet Analysis Tool to capture the flow of packets going out of the board.
I can only see the packets as they reach to the cores i.e, FM1->QM, QM, QM ->SW Portal. But the reverse is not there for these packets, as they are sent out of the network interface, i.e, from core to FM.
Could you please suggest what is wrong with the tool?
Sharath Chandra
