NAND flash replacement for P20x0 (internal or HW ECC required)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
We are looking to replace a Samsung K9K8G08U0D NAND on our custom P2010 board (running linux 2.6.35).
- We need the same footprint as K9K8G08U0D
- We need to boot from NAND (which we currently do).
- SW ECC is likely not an option due to performance concerns.
We initially hoped to use Micron MT29F8G08ABABA, but seeing that it:
- has 4K page size (only 512 and 2K is supported by eLBC - 4K support seems experimental?) and
- requires 4-bit ECC (eLBC only has 1-bit ECC) and thus would need SW ECC,
it is probably not an option.
We are now investigating Micron MT29F4G08ABADA, with 2K page size.
It still requires 4-bit ECC, but has internal/on-die ECC. Has anyone been successful using P20x0 with it?
I would very much like to know:
- What NAND flashes have successfully been used in various P20x0 (linux) projects.
- If any of the Micron MT29F4G08.. are supported by P2010.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The P2020 eLBC supports disabling ECC generation. Find the BR_DECC_SHIFT in u-boot configuration file.
Pavel Chubakov
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Usually u-boot provides NAND Flash configuration on the board.
Change u-boot configuration using u-boot source code.
U-boot configuration file is located in the u-boot source folder: /include/configs. This folder contains the .h files for the different boards.
See documentation on the following page:
http://git.denx.de/?p=u-boot.git;a=blob_plain;f=README;hb=HEAD
and
http://www.denx.de/wiki/view/DULG/UBoot
See NAND Flash configuration setting of the u-boot.
Pavel Chubakov
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Pavel, thank you for your reply. U-boot however does not currently support on-die/internal ECC.
Patches exist for on-die ECC, e.g.
patchwork.ozlabs.org/project/linux-mtd/list/?submitter=8164​
I would very much like to know if it is possible to use on-die/internal ECC with the eLBC NAND controller?
