Can I get the type and brand of the NAND flash that P1010 RDB is using? I only know that it is a SLC nand flash. I would like to know more details.
haowang
Hi, as the title said. I would like to know more details about the NAND flash that P1010rdb is using(e.g. how many blocks, how many bytes for the row and column addressing, etc.). If I can now the type and brand of the nand flash.
Thanks.
alexander_yakov
NAND flash used on P1010RBD is Samsung K9F5608U0D-PCB0
NAND flash used on P1010RDB-PB is Micron MT29F16G08ABABAWP:B
haowang
Thanks for your reply. Is there any documentation (like the P1010 RDB User Guide) exist?
Since I would like to know more details about what are exactly containing in the board. Could you help me?
Thanks.
alexander_yakov
P1010RDB board documentation and schematic files are available only with board, on USB stick supplied in board package.
haowang
Thanks again. For the Nor flash, on the fact sheet , it says it's 32M. Could you tell me the type of the NOR flash?
marius_grigoras
You simply can use CodeWarrior for finding all flashes supported by a board. The FlashProgrammer tasks will show you the device names.
For your requested device - S29GL256S90TFI01 (in CW you're showing a compatible device - S29GL256P).
Marius
