36-bit address in P2020rdb-pc
敏赵
I am using p2020rdb-pc. I download a 36bit .bin file to the board by codewarrior.
I get this:
Although it it show addressing= 36 bit, but flashstart= 0xef000000. The addresses are not 36-bit. It should be 0xf_ef000000.
Did I download failed?
Min Zhao
scottwood
Yes.  The physical address is 0xf_ef00_0000.  The effective address is 0xef00_0000.
scottwood
Those are effective addresses, not physical.
敏赵
Do you mean my NOR's base address has been assigned to 0xf_ef000000. It just don't show?
Min Zhao
scottwood
