"Initialization of TED-Kit 2 with serial number "AH06IOXS"failed.This TED-Kit 2box cannot be used and is not shown in hardware view."
Solved! Go to Solution.
I CAN FIX NXP TED KIT2
I'm also getting the same initialization failed popup while connecting the ted-kit 2.
have you solved the problem?
if no, I can help you
Thanks for reaching.
in my case that problem is solved.
I met the same problem, may I ask how to solve it?
Hi 32mao,
You need to restore the the firmware whichever available into the TED-Kit.
that will solved your problem.
Thank you for your answer, but I don't know how to restore the firmware. I can see that there are some ".hex" files in the "firmware" folder. Do I need to remove the box?
please asked to the supplier they will provide you the user manual with hex file for how to restore the TED-KIT firmware.
I haven't been able to contact the supplier. I called him but didn't get through. I wrote him an email but didn't get back. I am very urgent about this matter now. Can you tell me how you recovered it at that time? Does this need another software?
for flashing the hex file you need to download the flashmagic software.
may be one of the tutorial is available on YouTube(How to use flash magic software).
Ok, thank you for your quick reply.
I have the same problem, any solution for that? Thanks
HAW CAN I SOLVE THIS PROBLEM
