I using the PTN5150 as the cc for USB TYPE "OTG".
However, I only works with in "HOST" mode.
Does the VBUS control require for the OTG mode?
This is what I read from the log.
Thank you.
Hi CCC1,
it is not possible to provide power to the USB_OTGx_VBUS lines with the PF1510 without first accessing the PMIC via I2C.
With Best Regards,
Jozef
