noise on power supply
yojanse
Hi, im working with a mcu rt1050 and im using a laboratory power supply , the problem is when i energy a electromagnetic lock with a separate power supply i get the noise over the source (check the picture) and it restart my mcu.
Whats this error type ?
How can i solve it ?
yojanse
i correct the error, the problem was the inductor load, i used a reverse diode
yojanse
Hui_Ma
Could you regenerate the same behavior with RT1050 Evaluation board (MIMXRT1050-EVKB) ?
I would recommend customer to refer <MIMXRT105060HDUG> document about power circuit design for RT1050 chip.
Wish it helps.
Mike
