mpc5554 c code translate to assembly code help
1,665 次查看
juzi
 hello,
     i  need to  translate the following c code
             SIU.PCR[189].R=0X0100;
into  assembly code,i do not  how to do it.
   the code is for mpc5554.can you help me? thanks.
991 次查看
stanish
Hi Juzi,
you can disasembly any C-code directly in CodeWarrior IDE. Simply select or open the module you need to disassemble, click right and select "Disassemble" option from the menu .
Stan
