mclk clock output issue of sgtl5000
586 次查看
jackhua
The mclk clock of my sgtl5000 is provided by i2s, and sgtl5000 must go through 8 mclks to establish communication with i2c. However, I found that the registration of my i2s after sgtl5000 caused communication failure between sgtl5000 and i2c. Is there any way to make the driver of i2s before sgtl5000? I have tried to modify the registration priority of the driver of i2s but it has not worked. Here are some information system.map.pngdts.pngsgtl5000-mclk-i2c.png
1 回复
575 次查看
Bio_TICFSL
The sgtl5000 is working ok, but you i2s looks like is not the one that the sgtl5000 need, check the driver currently in the BSP it works.
