Dear Sir,
we are looking for the Lithium battery charging IC on the NXP website. the requirement as below:
1) meet for Automotive grade
2) the charge power need to larger than 100W, the charge current can be set 6 A
3) has some protect function, such as over current, over voltage, over temperature
would you like kindly help to recommend some Part number for reference, thanks.
Best regards.
Guofred
Solved! Go to Solution.
Dear Guofred,
I am afraid there is no such Li-Ion battery charging IC currently available in our portfolio.
We do have some Single-Cell Battery Charger ICs, but our main focus is on Wireless Charging.
Tomas
Dear Guofred,
Tomas
Dear @TomasVaverka ,
ok, thanks for your kindly help.
i would like to check it again, thanks.
Guofred
