In my design R=100k and C=1uF as I have unknown delay time in VDD_HIGH_IN and DCDC_IN and 1ms for DCDC_PSWITCH is not enough. so I increased the RC delay time. What will happen if DCDC_Pswitch delay is larger than 1ms.
Solved! Go to Solution.
Hi @Swezin ,
No issue would happen if you extend the delay for DCDC_Pswitch.
Kan
Thank you Kan for your quick reply. Another question,
The reset is not functioning. I measured the voltage, and it drops to zero when I press the switch, but the chip does not reset.
Hi @Swezin ,
Kan
Hi @Kan_Li
Thanks for your fast response. Another question.
