i.MX6UL with NAND Flash
lizboxy
Could you share the way to set the speed of communication with NAND Falsh when i.MX6UL boot?
TKs!
art
The NAND flash timing parameters at boot time can be somehow controlled with the BOOT_CFG signals/fuses and the Flash Configuration Block data. For details, refer to the Sections 8.5.2.1 "NAND eFUSE configuration" and 8.5.2.3 "Firmware configuration block" of the i.MX6UltraLite Reference Manual document.
Artur
