gstreamer vpu plugins and qt on imx27
2,192 次查看
xpc
I have to create a Qt-embedded application, which plays video file, using the vpu plugins of gstreamer on i.mx27, without X server.
But it seems that there is no gstreamer video sink, compatible with qt-embedded.
As I understood, the phonon multimedia framework, works with gstreamer. But obviously it does not give the opportunity gstreamer to work with certain plugins, such as the vpu encoder/decoder.
Can someone give me any ideas, how to integrate gstreamer with vpu plugins in a Qt-embedded application?
Thanks in advance,
H. Tsenov
2 回复数
986 次查看
jf_nicolas
I'm facing excatly the same issue.
Did you find any solution to this problem ?
Thanks in advance.
986 次查看
jviguera
Hi all,
Exactly the same problem here on an i.mx51.
Did anyone of you of anyone in the forum find a solution/clue?
Please, any idea posted in the forum would be appreciated.
Javier Viguera
