hello i am working with kirkstone yocto and tryin to add a python package to my image the bitbake of this package completes successfully and i tried it on the board and it works but when i do IMAGE_INSTALL this new packge in my custom layer.conf file the build fails
these are logs:
rania@rania:~$ grep -i "error" /home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/temp/log.do_rootfs.308129 ERROR: Unable to install packages. Command '/home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/opkg.conf -t /home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/temp/ipktemp/ -o /home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/rootfs --force_postinstall --prefer-arch-to-version install alsa-utils bash bluealsa connman connman-client connman-plugin-ethernet connman-plugin-loopback connman-plugin-wifi coreutils curl ffmpeg gpicview less makedevs media-files mime-support net-tools opkg packagegroup-base-extended packagegroup-base-tdx-cli packagegroup-basic packagegroup-boot packagegroup-core-boot packagegroup-core-weston packagegroup-fsl-isp packagegroup-machine-tdx-cli packagegroup-tdx-cli packagegroup-tdx-graphical packagegroup-tdx-qt5 packagegroup-wifi-fw-tdx-cli packagegroup-wifi-tdx-cli python3-httpx python3-pip rsync run-postinsts scooter-dash systemd-analyze timestamp-service udev-extraconf util-linux v4l-utils wayland-qtdemo-launch-cinematicexperience weston-xwayland xterm' returned 255: Installing kernel-module-error-5.15.148-6.7.0-devel+git.bfdbfb2c85fb (5.15.148+git0+bfdbfb2c85) on root Downloading file:/home/rania/pixii_os/pixii_os/build/tmp/work/apalis_imx8-tdx-linux/tdx-reference-multimedia-image/1.0-r0/oe-rootfs-repo/apalis_imx8/kernel-module-error-5.15.148-6.7.0-devel+git.bfdbfb2c85fb_5.15.148+git0+bfdbfb2c85-r0_apalis_imx8.ipk. configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator) configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator) Configuring kernel-module-error-5.15.148-6.7.0-devel+git.bfdbfb2c85fb.
This is a general issue, please refer these links:
Zhiming
i solved the problem it was because of the package python3-httpx i delete from the local.conf fix it then take it back and the build was successful this time
