Dear NXP support team,
I understand that the TJA1442AT (Aviary) product is a newer generation product than the TJA1044BT (Mantis).
However, the TJA1442AT product page on the NXP site recommends the TJA1044BT as a New Generation product, as shown in the capture below.
Which product should you actually recommend to your customer, and is it the last product released?
Below is capture image from NXP web site,
Deega Jung
Solved! Go to Solution.
Q: and is it the last product released?
[gw]This belong to typo, you can contact with your local NXP representative for this typo to check whether it will change or not.
Could you explain for my last inquiry?
Deega
That should be typo,TJA1442AT is the newer generation part.
Dear NXP Tech support team,
Thank you for your reply.
However, I recommend TJA1042BT as a New Generation Device on the TJA1442AT product page, and I would like to know why.
Refer to the link and below capture image with red box,
https://www.nxp.com/part/TJA1442AT#/
Deega
