Some BLE,2 power supply(3.3V or 3.6V),RF performance test results will be somewhat different.
Will KW38 be the same?Which performs better?
Hello @jingfang ,
Thank you in advance for contacting NXP community support. We do have a recommendation where the 3.6V is the maximum value. In this case this will variate depending on the application. We do not have an specific value recommended for this. Please let me know if I can help you on anything else.
