What is the start-up time of PCA85063ATT?
adevries
Contributor V
Is there any data available for the start-up time of P/N PCA85063ATT? The datasheet does not specify any kind of maximum start-up time, and I have an application that needs a 32kHz signal within 50ms of receiving power. Will PCA85063ATT be outputing a clock signal at that point?
guoweisun
The start up time should be several hundred ms,but the OSC output will be monitored to estimate the start up time.
adevries
Contributor V
Hi G.w. Sun,
Thanks for investigating this, I look forward to seeing what the results are.
