Hi JorgeCas,
I attempted to flash the eMMC on our custom board from a Windows 11 system using the latest UUU tool (Release uuu_1.5.201) downloaded from the link you shared earlier.
Below is the syntax I have used to flash:
uuu.exe -b emmc_all imx-boot-tagged imx-image-core-agility-20250912121110.rootfs.wic
However, the process seems to hang. I’ve attached the terminal logs for your reference.
When I run the same command/syntax again, it produces the following error also sometimes:
Error: fail open file: >emmc_all
Additionally, I have a question regarding the flashing script: could you please confirm whether using a custom UUU script (e.g., emmc_custom_all.uuu or emmc_custom_all.auto) is mandatory for this operation?
Thank you for your guidance.
Swathi
