Triac BT136-600
Triac BT136-600
AlexanderKey
Does Triac BT136-600 have UL or VDE certificates of conformity? If it does I would like to know the numbers of those certificates.
reyes
Support can be limited for this part since the BT136-600 Triac is no longer manufactured by NXP since 2009 as you can see in the Discontinuation Notice in the following link: https://www.nxp.com/wcm_documents/products/eol/dn65_a.pdf
BT136-600 is not UL recognized device.
Jose
AlexanderKey
Thank you for your answer.
