Hi Team,
We need One-time programmable device configuration done for pmic pf7100 designed for high
performance i.MX 8 processors
All default One-time programmed configuration file and OTP configured registers value
Hi Rahul,
please check the PF7100 configuration reports in the PF7100 product page. Then you can compare the description to the OTP register map in the Table 75. in the PF7100 datasheet.
With Best Regards,
Jozef
