The BFT92 I purchased appeared to have a pin fracture problem after soldering.Do you have BFT92 with copper pins?
cx365565583
LPP
Is it a single incident? How often does it happen? Do you bend the pins before assembling?
It is industry standard package. We had no problems with breaking the pins. If you got multiple fails, you may report CQI to the distributor who supplied this product.
BFT52 is provided in SOT32 package with iron nickel leads. It is not available with copper pins.
Pavel
NXP TIC
