TJA1153 CAN secure transceiver configuration
sobo
I'm using the eval board S32K3X4EVB-Q257, I want to use the CAN in normal mode.
I read that the TJA1153 need to be configure, but I can't find a datasheet or Application note to explain how to do so.
is there such document ? if no how can we configure the transceiver
thanks
Sophe
Tags (3)
diazmarin09
Hello Sophe,
I hope all is great with you.
I am afraid that such documents require an NDA.
If you have not signed the NDA with NXP yet, please submit a new case for my colleagues who are in charge of the NDA process and can eventually help you with that.
I hope this information helps.
David
diazmarin09
Hello Sophe,
David
