TJA1100 test mode for MDI return loss and conversion loss
1,250件の閲覧回数
kevin-mingdong_
We am carrrying a PMA test according the open alliance for our product that applies PHY tja1100 .Can not find the test mode for return loss and conversion loss.Which test mode should be configured?
3 返答(返信)
1,162件の閲覧回数
kevin-mingdong_
Hello Bulat
Kindly refer below information from equipment,it says that DUT should be configured to transmit slave signal.
but i don;t quite understand the meanings of transmit slave signal.There is no link partner in this test,then how to make 1100 to transmit slave signal.
pastedImage_1.pngud be
1,162件の閲覧回数
Bulat
It would be better to ask the tool vendor, which 100BASE-T1 test mode is to be used. Since it says about Slave Mode, try to use Test Mode 3.
Bulat
1,162件の閲覧回数
Bulat
I think you need to consult with requirements/recommendations of your test equipment.
Bulat
