TJA1043T Isolation system reference design
已解决
跳至解决方案
2,913 次查看
RheaGao
Hi ,I want to use CAN with wake up all the way and CHOOSE TJA1043T, but my system is an isolation system and adopts optical coupling isolation. I would like to ask how to deal with the power supply of THE Vio pins of TJA1043.  Is it connected to the VCC?  Is there a TJA1043 isolation design for reference?  Thank you very much!
1 解答
2,907 次查看
guoweisun
3 回复数
2,901 次查看
guoweisun
TJA1043 can't get the ground isolation between RX/TX and CANH/L.
2,908 次查看
guoweisun
You can select TJA1052I for isolation application.
TJA1052i Galvanically isolated high-speed CAN transceiver (nxp.com.cn)
2,903 次查看
RheaGao
Hi,I have seen the product TJA1052i, but I want to confirm whether TJA1043T can be used in isolation system?
