I bought a quantity of IC TDA8954J from a Chinese store on the basis that it is original parts. The amplifier circuit did not work with me in any way, noting that I implemented the scheme professionally .... I drew my attention that the terminal 23 (the Mode pin) is in the case of shorts with the chassis in all the quantity that I bought it .... Are these shorts normal in the IC?
Thanks very much for any help or clarification
any help ??
good day sir
I don't have samples in hand so can't test the Pin23 and GND,but they should not be shorted anyway.
Still suggest you buy samples from official NXP distributors below link:
https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS
For your issue ,can you confirm that your TDA8954 buy from official NXP distributors?
do you mean MODE pin short to which pin in your board?
