Soldering MRF101 directly to a copper Heatsink
TimHatch
I am wondering if it is a good idea to solder the MRF101 to a copper heatsink spreader.  It has been done on the other larger high power LDMOS items.
Tim
TimHatch
RafaR,
"our EVK we generally do direct soldering"
This helps a lot.
Tim
RafaR
Hi TimHatch
I recommend you check the link below:
https://www.nxp.com/docs/en/application-note/AN1955.pdf
For example, at our EVK we generally do direct soldering, but for your circuit first check the recommendations and verify your values.
Have a great day and best of luck.
