Setting NXP-Chip HTRC110 for frequencies higher than 3 kHz
1,170件の閲覧回数
K_Salewicz
Is there any information available about special configuration/workaround/solution strategies necessary to set filter parameters in a way that will allow the chip NXP HTRTC110 to work on frequencies higher than 3 kHz, like 6 kHz.?
3 返答(返信)
1,143件の閲覧回数
K_Salewicz
Thank you very much. It helpes.
1,144件の閲覧回数
K_Salewicz
Thank you ! It helped.
1,149件の閲覧回数
andreastruppe
This information can be found in the Datasheet in chapter 10.7 SET_CONFIG_PAGE. https://www.nxp.com/docs/en/data-sheet/037031.pdf
