SJA1105T - RGMII at 1.8V
jiri_naprstek1
Dear all, we would like to interface SJA1105T to the host processor at 1.8V (host processor can't do anything but 1.8V). The SJA1105 datasheet says RGMII operates at 2.5V only, however the core voltage and 1.8V possibility at other pins may suggest that 2.5V only might not be a hard requirement, but may be stated to maintain a standard compatibility or so.
May i kindly ask you, if SJA1105T RGMII (one port) would work at 1.8V?
Thanks a lot
Tags (3)
reyes
Unfortunately no, SJA1105T RGMII would only work for 2.5V. For RGMII voltage of 1.8V you would need to use SJA1105P/Q/R/S version of the device: https://www.nxp.com/products/interfaces/ethernet-/automotive-ethernet-switches/sja1105pel-qel-rel-se...
Jose
jiri_naprstek1
Hi Jose, sad news but thanks for confirming that. I wish the P/Q/R/S versions were on reasonable leadtime
Thanks, Jiri
reyes
Jose
