SJA1105QELY Thermal Values
canton
Dear Mr/Mrs,
I would like to know the following information about the SJA1105QELY component:
Max Tjunction
Thermal Rj-c
Thermal Rj-b
Thanks in advance,
Carlos Antón
TomasVaverka
Dear Carlos,
The thermal values are actually documented in the datasheet.
Tomas
canton
Dear Tomas,
Could you help me to get the following values that are not in the datasheet please?
  • Rj-c
  • Rj-b
If you couldnt answer, may you tell me the contact of someone that could hel me?
Carlos
TomasVaverka
Dear Carlos,
Let me double check if those thermal values are available and then I will update this thread.
Tomas
canton
Dear Tomas,
Tell me if im wrong, but the Rj-c and Rj-b values are not in the datasheet doesn`t it?
Carlos
