SJA1000 baud rate settings 1Mbps
kowalski100
I am using SJA1000 in a circuit with baudrate 1Mbps with 24Mhz crystal. I tried many setting but none of them worked. The emulator gives errors.
The CAN emulator (http://www.cananalyser.co.uk/candoiso.html) expecting sampling point (for 1mbps) to be at 80% but none of the settings gives sampling point at 80%. I don't know its sampling point issue or settings issue!!!
I used the following tools for settings:
https://www.kvaser.com/support/calculators/bit-timing-calculator/
https://www.esacademy.com/en/library/calculators/sja1000-timing-calculator.html
Any clue will be highly appreciable...
Kind Regards,
kowalski100
Finally it worked... The problem was bus impedance. I forgot to add 120ohms capacitor between CAN-H and CAN-L line.
kowalski100
JozefKozon
Hi Ijaz,
please provide your schematic with voltage levels and part values.
With Best Regards,
Jozef
