SGTL5000XNAAM vs SGTL5000XNAA3
jridings1
What is the difference between NAAM devices ( 10 years old ) vs NAA3 (current vers). Can a customer use the NAAM vers in the NAA3 socket? Data sheet doesn't address lineage from NAAM to NAA3. Thanks!
jridings1
Customer decided against using these. No further action required.
jridings1
Thanks for this, but this was not my question. NAAM devices are over 10 years old and Rochester has this inventory. Can NAAM product be used in an application designed for SGTL5000XNAA3. Never mind that NAA3 is also EOL, replaced by NAAB.
The question is what are the differences between NAA3 and NAAB? Thanks.
diazmarin09
Could you please share a picture of the Marking information on top of NAAM version silicon?
We could not find NAAM version information internally.
David
jridings1
diazmarin09
I hope this response finds you well.
I am afraid that the status of the SGTL5000XNAA3 is End of life. The current version of the device is SGTL5000XNBA3. Could you please confirm your customer´s device.
In this case for example, SGTL5000XNBA3 is exact pin to pin with SGTL5000XNAA3. The difference are shown in APCN.
David
