##uart Hi all,
I saw from the "Package/Quality" product webpage tab is possible to find out the MTBF and FIT values but there is no information about the conditions used for this calculation which are:
Temperature (°C) and Confidence Level (%). As well as the Manufacturing process for the part with the transistor size: 2.5^2um Bipolar, 0.4um CMOS, BiCMOS ....
Also many manufactures add the Activation Energy (eV)
- Could you let me know all these parameters for this device part?
- Is there any document backing up the FIT/MTBF information? web page or tool for pro-rate calculations?
thanks in advance
*B*
Solved! Go to Solution.
Hi Blas,
In order to get the requested MTBF and FIT data, please create a standart ticket.
Thanks!
Tomas
Hi Blas,
Thanks!
Tomas
Done, Case: 00095825.
Thanks for the link!!
