If I don't use the CTS signal, is it okay if it is not connected?
Is processing such as pull-up or pull-down necessary?
Solved! Go to Solution.
Dear Bbgbbg2020,
you can leave the CTS pin floating if unused.
With Best Regards,
Jozef
Dear Bbgbbg2020,
With Best Regards,
Jozef
