S32R45 no Platform in output->Modules.mak
1,090 次查看
longfeiwang
After importing the Platform module in EB tresos, then generate code, there is no Platform in output->Modules.mak, where is this configured?
1,032 次查看
petervlna
I just generated new project with same drivers are you and I can see platform there.
Please make sure you build has no errors.
In case your issue persist, please share more detailed issue analyzes so I can reproduce it here.
best regards,
Peter
1,078 次查看
petervlna
I will check it here. Platform is usually part of BASE module pluguin.
I will feedback you ASAP.
Peter
1,043 次查看
longfeiwang
Is there a new update now?
