S32G-VNP-EVB self-diagnositic test failed.
Search instead for
Tim_zhang
Hello friends, This morning I perform self-diagnosis test, but found test 18 is failed. Is there any one meet this issue before? How to fix it? thanks for your comments. Tim Parts of log: ----------------------------------------------------------------------------------------------- Test#18: LPDDR4 Initialization and Test Initializing DDR Step 1: Configuration of enabling partitions starts for DDR system Step 2: Configuration of DDR PLL DDR clock configurations done for 3200MT/s DDR PLL Frequency Modulation enabled and Fmod is 32KHz Step 3: Configuration of DDR clock source selection starts ***** ddr_init failed : TRAINING_FAILED ***** Initialization Failed Test#18: Test NOK -----------------------------------------------------------------------------------------------
Tags (4)
bpe
All support to the processor and the board you are working with is currently done via tickets. If you wish to receive recommendations from NXP with regards to the problem you described,  please open a Support Case.
Platon
