S-Parameter Data Request of Some Products
nacipekcokguler
Dear Responsible,
I have purchased some products as listed;
BGA2714
BGA2800
BGA2803
BGA2815
BGA2817
However, I could not find their s-parameter data on web. Can you provide me with these product's s-parameter or model data?
Naci
  • RF
nacipekcokguler
Dear Andrei,
I have checked the datasheets before and now a couple of times. However, I need the S-Parameter data as given in the datasheet of BGA2714 in section 8.3. Other devices' datasheets contain only the graphs of the scattering parameters and values at 3 different frequencies. Those data are useless unless they are given as in the table provided in the datasheet of BGA2714 in section 8.3. I cannot derive the numbers from the graphs in with a good precision, furthermore, phases are not available in those datasheets. Can you provide me with the scattering parameters as a table for each component?
Naci
andrei_skok
All available S-parameter data can be found in the Datasheets. We don't have any additional information available.
