Regarding center pad of CBTU02044
simhyeongjun
Dears,
On the Datasheet of CBTU02044, the Center pad is NC and recommends connection with GND.
Isn't it a problem to connect the pad that is not connected to GND internally to GND from the outside?
I'm curious about the role of the center pad. Is it a Thermal Pad?
Adam
TomasVaverka
Dear Adam,
The center pad may be treated as thermal pad and it is indeed recommended to connect it to PCB ground.
Tomas
TomasVaverka
Dear Adam,
Tomas
