Regarding PMEG3050EP
niteshsahay
I have used PMEG3050EP part for the protection from two supply rails but we observe the voltage is available at both the ends of the diode when one supply is ON.
Can anyone suggest me the reason for so cause.
Is PMEG3050EP is for different application.
I have attached my circuit for the reference.
Nitesh
Bulat
If you measure voltage on open ends, possible reason can be reverse current of the diode. In Schottly diodes this current is relatively high.
Bulat
