RF Modulator with MC44CC374 or MC44CM3734
brentdong
I am trying to build a A/V RF modulator for home security system,  connecting to TV set.
In the datasheet of MC44CC374, I can not see the  modulation output. but I found the output is DSB, (Double Side Band),  the band width exceed the CCIR  standard of 6M or 8M bandwidth.
My questions are:
1. Can MC44CC374 or MC44CM3734 be programmed to SSB ( Single Side Band) output?
2. What I can do to fit the output within 6M or 8M bandwidth of TV?
Thanks a lot if you can help.
  • RF
Tags (3)
Wlodek_D_
Senior Contributor II
Hello brentdong,
1. The MC44CC37x family of modulators is not configurable to SSB mode.
2. There is no simple solution for producing 6- or 8-MHz channel bandwidth in modulator - filtering to standard channel bandwidth is performed rather in TV receiver (IF SAW filter).
I hope this info will be helpful for your project.
Wlodek_D.
Wlodek_D_
Hello brentdong,
Wlodek_D.
